TwinTurbo.NET: Nissan 300ZX forum - Looks like a cheap short shifter
Subject Looks like a cheap short shifter
Posted by ttsmokin on July 21, 2014 at 10:30 PM
  This message has been viewed 189 times.
In Reply To Installed short throw shifter, now missing 5th gear shortly. posted by XTZ on July 21, 2014 at 06:12 PM
Message I would say the shifter is more than likely related to your 5th gear issue. If you still have it, go back to your stock shifter and see if you can get into 5th without issue.
There is really no adjustment on those short shifters so unless a bolt has come loose or it was installed incorrectly you can't do much. Like Zbullet said you should check you didn't overtorque the pivot bolt/nut, it should not be too tight or else the shifter is hard to move.
