TwinTurbo.NET: Nissan 300ZX forum - Can you verify the gauge is accurate?
Subject Can you verify the gauge is accurate?
Posted by ttsmokin on July 19, 2014 at 10:40 PM
  This message has been viewed 164 times.
In Reply To Compression test posted by blueridge on July 19, 2014 at 09:31 PM
Message You can re-test with the throttle held wide open, and try to see if some oil in the cylinders brings the compression up. The extra oil helps worn rings seal against the cylinder wall.
