TwinTurbo.NET: Nissan 300ZX forum - Time to grab the FSM
Subject Time to grab the FSM
Posted by ThisIsSparTTa on July 19, 2014 at 9:19 AM
  This message has been viewed 116 times.
In Reply To Electrical problem PLEASE HELP!:( posted by 3hundaZ on July 17, 2014 at 04:56 PM
Message You're going to have to do some troubleshooting work that will be complicated to explain here. Go to the electrical section of the FSM. You'll most likely just need the section on the combination cluster and climate controls, but you may also need the part at the beginning showing how everything routes around.
I'm battling a similar-ish problem right now with the circuit that carries all of the lighting, security, a/t controller and more on it. I found which wire leaving the fuse box is showing a short to ground, and now I get to see if I can find the short... Fun times.
