TwinTurbo.NET: Nissan 300ZX forum - You should be at normal idle with IACV plugged in
Subject You should be at normal idle with IACV plugged in
Posted by ThisIsSparTTa on July 18, 2014 at 10:40 AM
  This message has been viewed 239 times.
In Reply To What rpms should I be at when setting 15* timing? posted by dvice on July 18, 2014 at 01:32 AM
Message What your normal idle is depends on your ECU program. For a stock ECU, it should be ~750. [ http://z32.wikispaces.com/Idle+Control ]
However, I emailed SZ to confirm on my chip, and they set the idle target for 900.
Make sure your engine is up to temp too as the ECU will set a different timing on warmup. After that, follow the general advice for setting timing properly, where to get the signal from, etc.
