TwinTurbo.NET: Nissan 300ZX forum - Only comes in 5w-40
Subject Only comes in 5w-40
Posted by BlackholeZ on July 17, 2014 at 6:51 PM
  This message has been viewed 251 times.
In Reply To What weight do you Rotella guys use? posted by 300ZMang on July 15, 2014 at 09:18 AM
Message It's hard to judge changes that an oil makes. I've been running it for years, both on NA and TT engines. My NA would usually have a bit of valve train noise on startup with Mobil 1, a few lifter ticks, but that went away with the Rotella. My TT engine had a lot of oil buildup when I put it in. I cleaned as much as I could but didn't do a full rebuild. The Rotella has cleaned up the inside of the engine quite a bit. There are a lot of additives (like ZDDP) that our older engines like that modern oils have gotten rid of or have less of, but the Rotella still has.
-Dan
VTC Solenoid Caps and install instructions.
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
" Purrs like a sexually satisfied black panther." - BigTDogg
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
