TwinTurbo.NET: Nissan 300ZX forum - stock injector purple top vs nismo 555 purple top
Subject stock injector purple top vs nismo 555 purple top
Posted by supersh0cker on July 17, 2014 at 2:37 AM
  This message has been viewed 219 times.
Message How do you till if they are stock 370 or nismo 555, I pulled 6 purple top injectors with NO dot of any color on the tops, ecu is JWT for 555 injectors BUT I purchased car with what seems to be a swapped JDM that was not complete(half ass, hoses were not tighten, wires hanging)the injectors do look NEWER and the screws on the injector caps show obvious signs that is has been taken off before. and when I pulled them out they came out with no effort what so ever...? does that mean it didn't seal?
I researched here and I found that stock purple top has black or blue dots on top... just need clarification.
Where should I send them to be flow tested where I can keep my arm and leg
also there is a brown residue on the lower metal part right after the cap.. is that normal
