TwinTurbo.NET: Nissan 300ZX forum - Like I said, injectors.
300ZMang
on July 16, 2014 at 8:09 AM
Re: I really doubt O2 would cause that
posted by JT1237
on July 15, 2014 at 10:20 PM
However, you do need functioning O2's for your car to run right.
They could make your car run rich, but it wouldn't really sputter if rich, usually sputters horribly when lean.
HELP! TT sputter and backfire issues. please.
JT1237
23:19:43 07/11/14
Perform boost leak test. (n/m)
dvice
00:46:56 07/12/14
Re: Perform boost leak test.
JT1237
07:05:54 07/12/14
It could, yes (n/m)
dvice
15:45:01 07/12/14
Agree especially if it is on the driver side feeding the
SammybTT(TN)
21:11:05 07/12/14
Gotta do the Basics
Cjw3
08:42:14 07/12/14
hopefully the plugs are NGK's and gapped correctly (n/m)
300ZMang
11:14:22 07/12/14
my ultimate guess is injectors though
300ZMang
11:16:47 07/12/14
Re: my ultimate guess is injectors though
JT1237
22:28:22 07/12/14
Your engine is not firing on all cylinders.
ZaXxon
04:33:55 07/13/14
Had exact same problems after timing belt.
ThisIsSparTTa
08:38:57 07/13/14
Re: Had exact same problems after timing belt.
JT1237
19:50:32 07/13/14
ThisIsSparTTa
09:11:39 07/14/14
JT1237
22:20:47 07/15/14
Like I said, injectors. -
300ZMang
08:09:14 07/16/14
Re: Like I said, injectors.
JT1237
17:05:54 07/16/14
search "power balance test"
300ZMang
21:27:45 07/16/14
