TwinTurbo.NET: Nissan 300ZX forum - Re: Car dies when coming to a stop with the clutch pressed in
Subject Re: Car dies when coming to a stop with the clutch pressed in
Posted by ZTom on July 13, 2014 at 2:50 PM
  This message has been viewed 196 times.
In Reply To Car dies when coming to a stop with the clutch pressed in posted by Devonz32 on July 13, 2014 at 02:30 AM
Message The Z have IAC which is idle air control valve in the back of the intake platnuim on the driver side. It have adjustment screw. Use a flat tip screw driver and make the adjustment by turning in or out. If it still does not fix the problem you should replace it. Also it has an Air regulator mounted above it. I suggest you replace both at the same time.
