TwinTurbo.NET: Nissan 300ZX forum - Had exact same problems after timing belt.
Subject Had exact same problems after timing belt.
Posted by ThisIsSparTTa on July 13, 2014 at 8:38 AM
  This message has been viewed 210 times.
In Reply To HELP! TT sputter and backfire issues. please. posted by JT1237 on July 11, 2014 at 11:19 PM
Message I tried all of the stuff you've mentioned and it didn't matter. I had the same problem. I would accelerate okay up until about half throttle, then start stuttering and missing. I would have backfires on decel. I could build a decent amount of boost.
I finally bit the bullet, took the timing belt covers back off and counted the teeth on the timing belt. I was one tooth off at the crank sprocket, which was causing all of the timing to be off.
