TwinTurbo.NET: Nissan 300ZX forum - Overheating. Think it is fan clutch. Can you view my vid?
Subject Overheating. Think it is fan clutch. Can you view my vid?
Posted by ZUL8R on July 11, 2014 at 12:31 PM
  This message has been viewed 207 times.
Message Hi gang - I have suddenly begun overheating on my 1990 TT with 117k miles. Just bought the car a couple thousand miles ago.
Radiator was full of crap, flushed it. Coming out fairly clean now. Upper radiator hose gets hot so I believe thermostat is working. Radiator cap is fine, just replaced (couldn't find a tester that fit the cap). No hose leaks. Aux fan is working when I jumper temp sending unit.
In this vid I spin the fan after a minute of idling from a cold start. Is this fan clutch shot? Thank you.
[ http://youtu.be/HgQ18slvhJI ]
If you guys think this looks ok, I will probably try block tester next.
Thanks for any guidance!
Andy
"Yeah, it can break the tires loose."
