TwinTurbo.NET: Nissan 300ZX forum - No spark or fuel
Subject No spark or fuel
Posted by Z32TT-R on July 09, 2014 at 10:46 AM
  This message has been viewed 228 times.
Message Car was running fine, its 1990 TT 5spd
Pulled the motor for paint and just dropping it back in.
Getting no spark or fuel
Checked all fuses kickpanel,main box,battery fuse location everythings good
Car cranks won't turn over
Harness is oem only 800miles
All main harness grounds bolted to bare metal
Injector connectors have constatnt 12v
Visually checked spark and there is none
Tested 12v middle pin on coil pack connector with ignition ON and OFF and nothing.
Took CAS off and spun it and no clicking from injectors. Used known good CAS and still nothing.
Switched out PTU and nothing.
Fuel pump does not prime in ON position, but does when hooked straight up to the battery.
Fuel pump relay doesn't click, but is a good relay, and even tested it and it clicks.
Fuel pump relay when jumped, the pump turns on and primes.
Fuel lines & filter are hooked correctly.
Now the ecu, key in ON position it will not go into diagnostics mode, turning the knob does nothing, the red light just stays solid the whole time. I borrowed a friends OEM TT ecu and it does the same thing when connected.
I'm assuming this is harness related somewhere?
alt=" photo IMG_0367.jpg"/>
