TwinTurbo.NET: Nissan 300ZX forum - put the mani heat sheilds on at least. u cant even see
Subject put the mani heat sheilds on at least. u cant even see
Posted by LivinTheDream on July 05, 2014 at 10:08 AM
  This message has been viewed 198 times.
In Reply To Nice to have some input.... posted by Z ONLY1 on July 04, 2014 at 09:18 PM
Message Down there to worry about looks. And u can paint the heat shields also. I painted mine and can really only see it from under the car. If you have stock turbos it doesn't hurt to put the shields on them either. I wish i did. Deff put the fuel line shields back. Why expose the metal heat absorbing tubing for an explosive liquid to all that heat.. What's the only thing keeping gas from spraying on ur turbo or dp if u get a hose leak down there other than the shield. Can u post pictures of ur setup with ur aftermarket oil feed lines.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
