TwinTurbo.NET: Nissan 300ZX forum - Recirc valve vacuum line
Subject Recirc valve vacuum line
Posted by Metacom on June 29, 2014 at 1:01 PM
  This message has been viewed 493 times.
Message I'm replacing the BOVs one of the previous owners poorly installed with factory recirc valves.
Im also putting in a JWT single pop at the same time so I plan to remove the fascia to get the stock airbox ducts out.
Im a little confused on were the vacuum lines off the recirc valve will connect to, I thought they reached all the way up to the balance tube but I cant trace them.
Also it appears the line coming off the BOVs currently on connect to a larger vacuum line but I cant see past all the hard pipes.
Im going to replace all those vacuum lines, does anyone know the size vacuum line i'll need? I cant get my calipers up in there.
Where does the vacuum line on the recirc valve go to? and is it a straight connection to the vacuum source or is there some kind of short hard pipe along the way?
