TwinTurbo.NET: Nissan 300ZX forum - Wow. That sucks. Good luck with it. (n/m)
DVDBURN (MD)
on June 28, 2014 at 3:16 PM
Update inside
posted by -Grimm-
on June 26, 2014 at 12:33 AM
Code 51: Other ideas?
-Grimm-
19:22:39 06/19/14
Try running Resistance test from the ECU Plug.
Cjw3
19:46:08 06/19/14
I moved the 12V feed from constant to ECCS relay
-Grimm-
09:34:58 06/20/14
Resistance Check..
Cjw3
22:31:50 06/23/14
Re: Resistance Check..
-Grimm-
00:48:13 06/24/14
Also, I did measure resistance through the ECU plug...
-Grimm-
09:37:02 06/20/14
Well, since TTnet had been down I've had time to work
-Grimm-
00:56:27 06/23/14
I'm just going to keep adding things on here until...
-Grimm-
20:32:11 06/23/14
There is no way the code was still in your ECU.
DVDBURN (MD)
21:28:51 06/23/14
I wasn't sure how long the ECU could retain a code
-Grimm-
23:38:30 06/23/14
You're right
-Grimm-
00:49:29 06/24/14
Update inside
-Grimm-
00:33:30 06/26/14
Wow. That sucks. Good luck with it. (n/m) -
DVDBURN (MD)
15:16:54 06/28/14
Here are some pictures
-Grimm-
14:46:00 06/26/14
