TwinTurbo.NET: Nissan 300ZX forum - I moved the 12V feed from constant to ECCS relay
Subject I moved the 12V feed from constant to ECCS relay
Posted by -Grimm- on June 20, 2014 at 9:34 AM
  This message has been viewed 402 times.
In Reply To Try running Resistance test from the ECU Plug. posted by Cjw3 on June 19, 2014 at 07:46 PM
Message switched 12V (per the old writeup)
Also, when spinning the CAS I can hear the spark plugs firing in the cylinders. I'm beginning to think the issue isn't actually injector related (DVDBURN's now deleted post gave me some ideas to look into)
I haven't done any of those tests yet, hadn't thought about them due to code 51.
I will run it again today and see if I can hear any vacuum leaks or boost leaks. I can unplug my e-fan which should help me hear a bit better.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
