TwinTurbo.NET: Nissan 300ZX forum - Try running Resistance test from the ECU Plug.
Subject Try running Resistance test from the ECU Plug.
Posted by Cjw3 on June 19, 2014 at 7:46 PM
  This message has been viewed 328 times.
In Reply To Code 51: Other ideas? posted by -Grimm- on June 19, 2014 at 07:22 PM
Message Have someone wiggle the Injector Plug you are checking, while you have the Ohm meter in the Wireharness Plug that has been unpluged from the ECU..
The ECU Grounds Down the Injector Coils.. Is it possible the +12 you hooked to is somehow Flaky when running?
As for the Ruff Running.. have you done a Compression test, and a Boost Leak/Intake runner Leak check?
Cj
