TwinTurbo.NET: Nissan 300ZX forum - I have the fuel code fault as well when I pull the
SammybTT(TN)
on June 19, 2014 at 6:11 PM
Fuel temp sensor
posted by elvee18
on June 18, 2014 at 10:58 PM
codes. It will not turn on the CEL but it will show up. My problem appears to be an intermittent sensor that I plan to replace when I return home. It is easy enough to replace so I will try that before necking out the wiring.
Fuel temp sensor
elvee18
22:58:52 06/18/14
Re: Fuel temp sensor
zromtech
10:56:30 06/19/14
Are you going to tell us the Bits and Codes to Change?
Cjw3
13:18:34 06/19/14
Re: Are you going to tell us the Bits and Codes to Change?
zromtech
10:42:09 06/23/14
Thank you.. Give me some more to play with..
Cjw3
20:13:29 06/23/14
Re: Thank you.. Give me some more to play with..
zromtech
12:52:12 06/25/14
Re: Re: Fuel temp sensor
elvee18
16:08:54 06/23/14
I have the fuel code fault as well when I pull the -
SammybTT(TN)
18:11:28 06/19/14
Did you ground the fuel rail to the engine?
Woody75 (Denver)
14:26:06 06/23/14
