TwinTurbo.NET: Nissan 300ZX forum - also my symptoms of worn CAS drive pin were:
Subject also my symptoms of worn CAS drive pin were:
Posted by dvice on June 13, 2014 at 6:29 PM
  This message has been viewed 594 times.
In Reply To JWT chromoly CAS spline/drive pin posted by dvice on June 12, 2014 at 09:14 PM
Message - idled fine, cruised fine
- bad hesitation when cold
- boost came on quickly but power wasn't there, severe power loss
- random stuttering/hesitation
- timing did NOT wander when checking it, was very stable
- PTU loop claimed I was at 15 when CAS was turned 3/4ths counterclockwise, spark plug wire on #1 revealed impossible to get to 15, even turned all the way counterclockwise it would be at 0 degree timing (that's zero). turning it clockwise and timing went into the abyss past 0 (negative timing?) and car would want to die
