TwinTurbo.NET: Nissan 300ZX forum - The FICD can be unscrewed. I don't think you can
Subject The FICD can be unscrewed. I don't think you can
Posted by baggar11 on June 13, 2014 at 4:30 PM
  This message has been viewed 689 times.
In Reply To Looking for some guidance (Code 34/engine harness pl posted by rnacion on June 13, 2014 at 04:08 PM
Message purchase it separately though. Junk yard or used AAC/FICD unit will be your best bet if you don't want to fork down the $300 for a new unit.
I'm betting that your knock sensor connector connection has probably corroded. Unless you take off the plenum, upper and lower manifolds, you have to remove the transmission to get to it. Or do the knock sensor relocation with a new pigtail.
You may be lucky though, and your mechanic got the knock sensor connector mixed up with the other connector that looks the same in the back. I forget which one it is. Try swapping it when you find it.
Knock sensor looks like this connector though(To ECU)
-baggar11
1987 300zx n/a (sold)
1990 300zx TT
