TwinTurbo.NET: Nissan 300ZX forum - Be advised low compression can result from valves too
Subject Be advised low compression can result from valves too
Posted by aLL_youR_Z_aRe_beLOnG_tO_uS on May 31, 2014 at 10:31 PM
  This message has been viewed 195 times.
In Reply To TT head Swap posted by macwizz77 on May 31, 2014 at 04:40 PM
Message Be advised low compression can result from burned or sticking valves too, not just piston rings or head gaskets. In comparing the NA/TT heads, the TT heads have harder exhaust valves due to higher exhaust temps, the NA valves will be more prone to damage, such as burning a valve.
From my saved info, if this helps any, you should have phase II heads in 94 using new style injectors and lower plenum, main issue is matching the lower plenum/injectors to the heads.
HEADS:
Phase I
90-92 (30P)
90-94 (40P)
Phase II
93-96 (10Y)
95-96 (48P)
