TwinTurbo.NET: Nissan 300ZX forum - The bolt is for the driver side exhaust fitting. It's
Subject The bolt is for the driver side exhaust fitting. It's
Posted by jzack on May 30, 2014 at 11:03 PM
  This message has been viewed 230 times.
In Reply To egr delete questions part 2. posted by iamdan012 on May 30, 2014 at 05:37 PM
Message where the pipe on rear of engine runs between EGR valve and the exhaust. See this web page courtesy of member Yugobernie: [ http://www.yugobernie.com/plugs.html ]
PS - No real need to remove the whole (red) pipe, just cut it near the bend by the brake reservoir and remove that end from the exhaust manifold fitting. Then install the plug.
I recommend plugging the vacuum lines but leaving the EGR solenoid connected to the car's harness. Unless your ECU has been re-tuned to ignore it - unplugging will cause a trouble code. So just leave the solenoid connected. It's possible to fool the ECU with a resistor in place of the solenoid but why bother, its pretty hidden.
