TwinTurbo.NET: Nissan 300ZX forum - No Lift Shift Wiring
Subject No Lift Shift Wiring
Posted by krstull93 on May 28, 2014 at 7:13 PM
  This message has been viewed 303 times.
Message Im running aem v2 and now that it is warm out I am going to run 3 step (No lift to shift). My goal is to wire the switch through the neutral position switch (clutch switch), which on the pinout is pin 44 and on the aem diagram shows switch 4. I am guessing that when the clutch is depressed it turns to a closed loop ground. Has anyone ran this setup or anything close. If not I plan on messing with it until I can get the proper setup and I will post back incase any questions pop up on this topic for future reference.
