TwinTurbo.NET: Nissan 300ZX forum - I see
Subject I see
Posted by ZXRider on May 28, 2014 at 1:59 PM
  This message has been viewed 245 times.
In Reply To Re: So there is no relief valve posted by BeBoosted on May 27, 2014 at 01:54 PM
Message I spent some time and read about the AC system in the Z32 from the Z32 wiki site. It appears that I will not be able to tell if there is any r134a in the system unless I take it into a shop. I guess I will just replace the radiator and while the radiator is out I will attempt to clean the condenser.
I am monitoring the temperature using a techtom mdm-100 which gets the reading from the temp sensor for the ECU. The sensor is good, I verified by checking its resistance.
I would like to avoid aftermarket radiator as the car is an AT and I would like to avoid having to mock up a cooler for the ATF.
I have nightmares about that happening...I'd be the poor bastard you'd hear about on the news that gets killed by a softball-size chunk while spreading out my body over the hood and screaming "Nooo!" (Having a conversation about hail damage) - BradZ (FL) on March 25, 2005 at 9:56 PM
Tell your friend that you could take a dump, light it on fire and that would be hotter shit than his car. Probes suck, that's just all there is to it. - 300ZXpert (someday) on April 04, 2005 at 11:35 PM
P.S. You REALLY are on here at ALL hours! And I thought I was bad! :) - zmenon on August 16, 2005 at 3:06 AM
LOL...2+2 drivers should grow mullets..."Business in the front...party in the back" ;) - BradZ (FL) on November 29, 2005 at 4:45 PM
