TwinTurbo.NET: Nissan 300ZX forum - Re: Is it critical to Assembly Lube new conrod bearings?
Subject Re: Is it critical to Assembly Lube new conrod bearings?
Posted by wild_maxx on May 25, 2014 at 6:58 AM
  This message has been viewed 241 times.
In Reply To Is it critical to Assembly Lube new conrod bearings? posted by OverZealous (CT) on May 25, 2014 at 12:39 AM
Message Yes you should use assembly lube but if the engine will be back up and running in a few days then you could get away with using motor oil. I used the redline assembly lube and really liked it. It sticks to the bearings and didn't dry out while sitting on the engine stand for 6 months.
