TwinTurbo.NET: Nissan 300ZX forum - Re: Engine - Transmission years
Subject Re: Engine - Transmission years
Posted by brian913 on May 25, 2014 at 6:32 AM
  This message has been viewed 156 times.
In Reply To Engine - Transmission years posted by quantummechanic on May 24, 2014 at 07:58 AM
Message I had a similar problem. I have a 93 with some other year engine in it. I called Nissan and was told they did not keep track of the numbers and years. 90-93 have a different kind of cam gear where the variable valve timing is, vs the 94-95 valve timing gears. 96 does not have the variable valve timing I believe. The ECU's may give you a clue too.
