TwinTurbo.NET: Nissan 300ZX forum - If it is the driver's side turbo hose, you would need to
Subject If it is the driver's side turbo hose, you would need to
Posted by doug8867 on May 24, 2014 at 12:49 PM
  This message has been viewed 297 times.
In Reply To Re: Here's a posting from another forum - the hose posted by skyline2693 on May 24, 2014 at 07:16 AM
Message remove the transmission to get to it from underneath, otherwise you can't reach the hose clamps. Maybe if you removed the driver's side down pipes you might be able to reach it... it's tucked pretty high up. When I replaced my clutch I replaced that coolant hose as a preventative measure.
However, you should double check that it's not the larger heater core hoses at the rear of the engine. I've had to replace those before and they can be done from the top with some patience and the right tool extensions. If you were going to remove the plenum anyway, then it would give you more space to do it.
