TwinTurbo.NET: Nissan 300ZX forum - I'm going to tag on my similar issue...
Subject I'm going to tag on my similar issue...
Posted by -Grimm- on May 23, 2014 at 12:07 AM
  This message has been viewed 202 times.
In Reply To Soft clutch pedal posted by Adamo on May 20, 2014 at 09:06 PM
Message To get an opinion.
My car is complete minus my clutch being bled (and oil pump primed). Has Z1 one piece SS clutch line
I attempted to bleed the clutch but can't get it to improve. Never had an issue before but never bled a vacuum assisted clutch.
So it has light resistance the first 3/4 of travel, then it feel the clutch disengaging, but just the last little bit. Not enough to fully disengage.
I bled it several times and it never improved, including manually bleeding the slave itself (compressing it to ensure no air).
I can see the slave pushing the fork. It rests against it disengaged, pushed out maybe a little less than an inch. The slave piston feels pretty loose inside the cylinder, which may be a sign it's shot?
Also, when I open the bleed screw without pressing the pedal (reservoir open) the fluid flows out and empties the reservoir, although I don't know if that is normal or not either.
So, any ideas? I figure either:
-needs more bleeding?
-bad master
-bad slave
-both?
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
