TwinTurbo.NET: Nissan 300ZX forum - VTC isn't disabled from a bad speed sensor.
Subject VTC isn't disabled from a bad speed sensor.
Posted by zromtech on May 19, 2014 at 11:45 AM
  This message has been viewed 163 times.
In Reply To IIRC vtc uses the speedo sensor, so you may be missing out posted by JonnyZ(SoCal) on May 18, 2014 at 10:11 PM
Message The ECU doesn't check for a speed sensor fault code when activating the VTCs. However, there is a minimum vehicle speed at which the VTC will be engaged. On both the TT and NA the minimum VTC speed is 0 (i.e. VTC can be engaged at any speed greater than 0).
In other words, I wouldn't worry about the VTC in this case.
