TwinTurbo.NET: Nissan 300ZX forum - latest test
Subject latest test
Posted by wickdGSXR on May 17, 2014 at 5:50 PM
  This message has been viewed 255 times.
In Reply To external wastegates and HKS EVC 6 posted by wickdGSXR on May 17, 2014 at 04:37 PM
Message controller set to P for Poppet (aka external)
wastegates are allowing 11 psi stand alone.
set standard boost to 11, setting A to 11 and did a pass=11psi
Setting A to 17 psi no change
change setting A offset from 100 to 190 no change.
Swap middle and outer hoses no change.
Set controller for S (internal).
set everything for 11 psi and it hits 18psi
reduce setting A offset from 100 to 20 and it's still 18psi
car idles fine and will obviously build boost.
I'm giving up for now, setting wastegates manually for around 18 psi and going dragracing in Redding, CA
