TwinTurbo.NET: Nissan 300ZX forum - Re: Suggestions for Antenna Fiz
Subject Re: Suggestions for Antenna Fiz
Posted by 1T9T9Z1 on May 17, 2014 at 11:04 PM
  This message has been viewed 170 times.
In Reply To Suggestions for Antenna Fiz posted by gbhrps on May 17, 2014 at 03:09 PM
Message Thank you for your response. I am definitely going to take the antenna apart and clean/regrease it. I made a mistake in my original post, the "relay" that I said that i swapped out, was actually the timer. It looks like a large relay. Changing it did not remedy the problem. I will check the ground, also will check the connection at the radio just in case something was disconnected. So far I had two people on TTnet and one person online that is pretty savvy with the bose stereos tell me to start by cleaning out the antenna, regrease and reinstalling. I need to start there. If that does not work then I can jump back on here and update my post. Thank you for your help! Have a great weekend. ~jeff
