TwinTurbo.NET: Nissan 300ZX forum - Re: Front Wheel hub / knuckle....
Subject Re: Front Wheel hub / knuckle....
Posted by Metacom on May 17, 2014 at 3:27 PM
  This message has been viewed 232 times.
In Reply To Front Wheel hub / knuckle.... posted by Ketch on May 16, 2014 at 10:04 PM
Message It helps to have two people if this part gets stuck.
We carefully tapped into two pry bars, both people attempt to pry it off at the same time, itll drop quick when it does. A pickle fork might work as well.
The knuckle will get some nicks on it...
There is a rubber seal inside there that might get messed up so you'll need to replace that if it does.
