TwinTurbo.NET: Nissan 300ZX forum - I have removed that part for bearing replacement.
Subject I have removed that part for bearing replacement.
Posted by JMartz on May 17, 2014 at 11:05 AM
  This message has been viewed 255 times.
In Reply To Front Wheel hub / knuckle.... posted by Ketch on May 16, 2014 at 10:04 PM
Message There is no way to push it out with a press as Nissan did not provide a support surface. The only way to remove it, is with a 3/4" diamiter 10" long brass rod and a short handle sledge hammer. No need for heat. If you heat they will ooze badly. Place the knuckle over a couple of same hight blocks of wood that allow clearing the floor by the flange side of the stub axle. Wack at it with patience. It will take a while, but it will come out. Read the FSM, that is the recommended (an one and only) way to separate the stub axle from the aluminum knuckle.
