TwinTurbo.NET: Nissan 300ZX forum - Re: Not sure why it would do this but when the car is
Subject Re: Not sure why it would do this but when the car is
Posted by 1T9T9Z1 on May 17, 2014 at 10:24 AM
  This message has been viewed 168 times.
In Reply To Not sure why it would do this but when the car is posted by jzack on May 17, 2014 at 08:45 AM
Message Thank you for your response. Yes, I would like to try a different antenna that is known to work on another car to see if this antenna is the problem. Process of elimination has always been a great way to figure out this type of problem but I only have this antenna. I did replace the mast because the old mast's cable was broken. Come to think of it I could try to remove the mast totally and "test-run" it that way. If the antenna motor runs correctly then I know the problem resides in the antenna mast somewhere. Most likely lack of lubrication or foreign debris in in the gear chamber. Any tips on lubrication for the mast cable? I have wheel bearing grease and white lithium grease available but not sure if this is what is right for the job. Thank you again for your help. Have a great weekend. ~jeff
