TwinTurbo.NET: Nissan 300ZX forum - Bad or mis-adjusted TPS
Subject Bad or mis-adjusted TPS
Posted by ThisIsSparTTa on May 16, 2014 at 8:33 AM
  This message has been viewed 228 times.
In Reply To Z32 idle problem posted by 1996 Z32 N/A on May 15, 2014 at 09:02 PM
Message [ http://z32.wikispaces.com/Throttle+Position+Sensor ]
Test your TPS and then make sure its set right. I'm willing to bet the switch that signals the "idle" state is either failed, or isn't working properly because you don't have the TPS set right.
