TwinTurbo.NET: Nissan 300ZX forum - Be careful about it though
Subject Be careful about it though
Posted by -Grimm- on May 15, 2014 at 1:40 PM
  This message has been viewed 248 times.
In Reply To Re: Is my rear subframe okay, or need to repaired/replaced? posted by Lue's Student on May 15, 2014 at 11:35 AM
Message Would be a good idea to double, triple check some measurements of the body before buying a new subframe, in case anything else deflected.
Long story short, you may run into extra work trying to align everything if theres even the slightest deflection.
Long story, still long:
When pulling my engine I noticed the car had been in an accident, front drivers side (wrinkled frame tube, right above the sway bar mount). The tension rod mount and impact absorber seemed to be the only things bent, so I thought it would be an easy swap.
Bought all the parts, and none of the bolt holes lined up. I ended up having to mill slots in the tension rod mount and aluminum impact bar to be able to align everything, hammer out my lower crossmember, and space the impact absorber with shims to angle it properly to get near fitting. Not happy about it either. Not fun.
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Building)
2004 G35 Sport 6MT (DD)
