TwinTurbo.NET: Nissan 300ZX forum - lean condition..... help
Subject lean condition..... help
Posted by poorkid_Z on May 15, 2014 at 2:12 AM
  This message has been viewed 517 times.
Message So I'm still learning all about tuning and building cars. I recently finished a TT conversion/ build project that has taken me ~6 years.
Motor had 164 miles ran beautifully then developed a chirp found a failed new t belt pulley. Also found that the timing was off a tooth (between the 2 intake cams) replaced the PE SS belt with an OE with marks. After that was fixed I drove a couple miles then installed my fuel pressure gauge. The fuel pressure was at 85psi at idle! (that explained the noisy fuel pump). Replaced the new (failed?) Nissan regulator with an adjustable Aeromotive regulator. Fuel pressure is now good. I originally set it at 35psi with no vacuum but bumped it up to 45psi with vacuum at idle. The car runs lean. I changed the fuel injector K value using my Zemulator to compensate but it seemed to have no change under boost/load.
I have a stock TT Federal Manual map loaded.
The k value was at 290 and ran perfect with timing off and 85psi fuel pressure. Now with the lowered pressure the car runs lean.
I adjusted the k value up and down since I really have no idea what I'm doing and haven't dared to touch the actual maps.
K value at 200 made the car very lean at idle.
k value at 345 made the car rich at idle.
The cruise ratio and under load seemed to have little if no effect between the changes.
Attached are 2 data logs, the first data log is a 3/4ish throttle from 1st to 3rd or 4th gear. The 2nd is just a light throttle in 1st and 2nd gear.
data log 1
data log light throttle
Here are the current engine related modifications:
88mm weisco pistons
Eagle H bean rods
cleavite 77 bearings
rotating assembly balanced with flywheel and crank pulley
ARP Head and main studs
JWT R4 cams
JWT single HD valve springs
JWT VTC springs
NA heads with Iconel exhaust valves
300 degree fuel rails (parallel feed)
740cc injectors
Aeromotive compact adjustable fuel regulator
stainless steel fuel lines
MS manifolds
GT2560r turbos
Selin translator (set to average)
dual intake/ mafs
new lifters
new pulleys
UR crank pulley
OE timing belt
OE TT Fuel pump/ NA controller
95TT harness
95 Cam sensor
all sensors on motor are new
Zemulator v1.5.3
plx m300 wideband
SZ 2.5 downpipes
SZ 2.5 test pipes
HKS Hi power exhaust
Greddy profec b2 boost controller (currently off for break-in period)
boost and fuel pressure gauges
Stillen ICs
upper hard pipes
Mishimoto radiator
Larger oil cooler
RPS segmented flywheel
RPS max clutch
I may have forgotten something but any help would be greatly appreciated. I am going through Z withdrawals.
