TwinTurbo.NET: Nissan 300ZX forum - Vacuum at idle is normal...
Subject Vacuum at idle is normal...
Posted by TyTyIsFly27 on May 14, 2014 at 10:06 PM
  This message has been viewed 1048 times.
In Reply To Oh sorry I misread. posted by dvice on May 14, 2014 at 09:11 PM
Message My gauge reads inHg, and it sits right at -20, so right around -10psi.
From what I've seen it increases properly at a 1:1 ratio with boost, but its hard for me to watch past a certain point since my boost gauge is on my A-Pillar, and Fuel Pressure gauge is in my din slot.
I noticed today that the fuel pressure will sometimes jump around a little bit here and there at idle. sometimes it will dip just under 40, sometimes it will jump closer to 50. Something is definitely going on.
I don't know if the fuel pump controller could cause the issue, since running an NA pump controller with a TT pump causes no such problems... but if it worked for someone else, I suppose I'll add it to my list.
I've been looking at an Aeromotive adjustable FPR, that I think will be my next step. Would anyone advise against this, even if I am only going to set it back to the stock level?? I don't really think there is any other things to check other than the controller; but again, that just doesn't seem to make sense.
Any advice is appreciated.
