TwinTurbo.NET: Nissan 300ZX forum - Rebuild it.
Subject Rebuild it.
Posted by ZaXxon on May 14, 2014 at 2:49 PM
  This message has been viewed 254 times.
In Reply To Car was underwater. posted by Vileside on May 14, 2014 at 01:24 PM
Message If you cranked the motor with water in the oil pan, then you pumped water through all the oil passages, bearings, TURBOS, etc. Was it salt water?
From your profile, it looks like you have put some good money into your car, so you don't want to mess that up.
Also, dont forget your tranny, there is a vent on it that probably let water in it. Also you may want to make sure that the clutch and fly wheel are clean.
Not sure if there is a vent on the diff, but may want to verify that.
DSCN1525
