TwinTurbo.NET: Nissan 300ZX forum - Check the fan relay before anything else
aLL_youR_Z_aRe_beLOnG_tO_uS
on May 08, 2014 at 6:24 PM
What could cause the aux cooling fan to always run?
posted by Marshall
on May 07, 2014 at 03:50 PM
You can always swap an identical relay with the same numbers on it to test it, common problem on all cars. If your A/C is turned on this can make the fan run to cool the condenser, if so, turn the A/C off.
Marshall
15:50:02 05/07/14
What do you mean by often?
Tanley
17:48:48 05/07/14
Just about all the time
Marshall
15:17:32 05/09/14
If your ECU is running in "limp mode", ie an error was
Dark Diver
03:59:36 05/08/14
There were no ECU codes.
Marshall
15:19:13 05/09/14
Check the fan relay before anything else -
18:24:28 05/08/14
