TwinTurbo.NET: Nissan 300ZX forum - EGTs are affected by a number of different engine parameters
Subject EGTs are affected by a number of different engine parameters
Posted by Tanley on May 08, 2014 at 7:11 AM
  This message has been viewed 201 times.
In Reply To passenger egts run colder at start with rough idle... posted by GitNMyBelly on May 07, 2014 at 09:55 PM
Message and are difficult to use as diagnostic tool. That being said, the fact that there is a rough idle that smooths out, a difference in EGT temps on the passanger side cylinder bank and you just installed 740s. I would be double checking your injector installation i.e. a pinched o-ring. You could have a small leak that is puddling fuel when the car is off and idles rough until the extra fuel is burned off.
Did you get the ECU tuned for the 740s?
