TwinTurbo.NET: Nissan 300ZX forum - mind = blown...I bow to the sensei :) (n/m)
Zvil (FL)
on May 06, 2014 at 10:07 PM
If your running a factory tune...........
posted by Greg D. (Specialty-Z)
on May 06, 2014 at 09:06 PM
The most frustrating and elusive idle problem ever
Silens
13:05:58 05/01/14
What kind of intake do you have? Stock, JWT, etc. (n/m)
SirpriZ
15:45:14 05/01/14
Just stock with a filter, no airbox. (n/m)
Silens
16:46:11 05/01/14
Does your set up use a low speed drivability hose? (n/m)
SirpriZ
17:15:32 05/01/14
Not that I'm aware of.
Silens
17:22:57 05/01/14
The problem that I had in mind would only occur if you have
SirpriZ
17:23:38 05/01/14
nope, I wish lol.
Silens
17:45:10 05/01/14
Sounds like either the throttle plates are too far closed,
18:16:48 05/01/14
Re: Sounds like either the throttle plates are too far closed,
Silens
12:04:15 05/02/14
PCV system ok? (n/m)
BarryGZX
19:25:37 05/01/14
Re: PCV system ok?
Silens
12:04:51 05/02/14
You say Wideband.. Only One?
Cjw3
11:53:39 05/02/14
Re: You say Wideband.. Only One?
Silens
12:06:58 05/02/14
Re: Re: You say Wideband.. Only One?
Cjw3
12:38:19 05/02/14
you should check your narrow bands
Zvil (FL)
00:38:26 05/03/14
Re: you should check your narrow bands
Cjw3
08:34:38 05/03/14
stock 02 sensors are used during closed loop only = idle (n/m)
The Devils Z
19:42:23 05/03/14
Re: stock 02 sensors are used during closed loop only = idle
Cjw3
23:13:17 05/03/14
you may be right -- it get it backwords - but they are only
The Devils Z
11:25:39 05/04/14
I believe initial start up until prescribed temp is open
SirpriZ
15:32:06 05/04/14
Idle is ALWAYS in Open Loop.. Read the Book (n/m)
Cjw3
16:39:08 05/04/14
my Z must have an abnormal quirk then
Zvil (FL)
16:52:50 05/05/14
"idle" is when the ECU sets the ignition timing at 15
Cjw3
19:36:24 05/05/14
Depends on the tune.......
17:48:12 05/06/14
Well, my 3 NA's are open loop at idle.. I've watched
Cjw3
20:42:14 05/06/14
21:06:03 05/06/14
mind = blown...I bow to the sensei :) (n/m) -
Zvil (FL)
22:07:08 05/06/14
Very Nice..
Cjw3
23:33:32 05/06/14
Look inside for post and u-tube by customer showing idle....
13:54:43 05/07/14
