TwinTurbo.NET: Nissan 300ZX forum - Did you set the engine per the t-belt FAQ before
Subject Did you set the engine per the t-belt FAQ before
Posted by jzack on May 05, 2014 at 9:43 PM
  This message has been viewed 170 times.
In Reply To Timing belt question. posted by GotTwins90 on May 05, 2014 at 06:20 PM
Message removing the belt? If not - they could have been at rest already?
If engine was set per the FAQ valves won't be at rest when the belt is removed. Actually one might stay put but touching it a bit should cause it to spring to the full resting position. Intake side if I'm remembering correctly?
