TwinTurbo.NET: Nissan 300ZX forum - "idle" is when the ECU sets the ignition timing at 15
Subject "idle" is when the ECU sets the ignition timing at 15
Posted by Cjw3 on May 05, 2014 at 7:36 PM
  This message has been viewed 470 times.
In Reply To my Z must have an abnormal quirk then posted by Zvil (FL) on May 05, 2014 at 04:52 PM
Message and it will try and settle the Speed ( 750 I think from memory ) and then run the mixture at a Fixed amount..
The ECU will only enter "Idle" when the TPS is at .4 to .5 Volt, and the 'Idle Switch' is also made. There is also a prescribed Min/Max Engine temp that the ECU will let this happen. To Cold, and the Engine is still in warm up mode, To Hot and the ECU will Idle up and do funny things with fuel cut..
Cj
