TwinTurbo.NET: Nissan 300ZX forum - UPDATE : 68k resistor is the correct choice to override EGR
Subject UPDATE : 68k resistor is the correct choice to override EGR
Posted by Black95 on May 04, 2014 at 9:19 PM
  This message has been viewed 404 times.
Message I searched a lot of posts to confirm it, but like most issues, people only post when the normal solution is not working for them. Not their success in solving the issue.
When I tried the 1 mega ohm resistor for the knock sensor, it worked by twisting the ends of the resistor like a paperclip. This did not work for the EGR. I had to build a "jumper wire" with the resistor in the middle.
I am only posting this so the next person doesn't need to waste as much time.
EGR delete , resistor, bypass, 68k ohm
  • UPDATE : 68k resistor is the correct choice to override EGR - Black95 21:19:01 05/04/14
