TwinTurbo.NET: Nissan 300ZX forum - Verify all cylinders are firing..spark and injectors
Subject Verify all cylinders are firing..spark and injectors
Posted by ZaXxon on May 03, 2014 at 3:16 PM
  This message has been viewed 200 times.
In Reply To Re: ^^^This. You may have jumped a tooth on your belt. posted by TwinTurboByrd on May 03, 2014 at 01:12 PM
Message Is the switch on the Selin translator in the correct position?
What kind of boost controller do you have?
Do you have an adjustable fuel pressure regulator? What kind of fuel pressure are you running?
Did you check for boost leaks? When you spool up, what kind of boost are you obtaining?
Update you profile.
DSCN1525
