TwinTurbo.NET: Nissan 300ZX forum - Re: A couple things I forgot to mention
TwinTurboByrd
on May 03, 2014 at 1:07 AM
posted by michaell32 (FL)
on May 03, 2014 at 12:55 AM
Yea i planned on checking boost leaks tomorrow. The ignition timing is a long story. Ive always had an issue with getting the time right. If its set on 15 degrees it makes NO POWER
Selin intake
TwinTurboByrd
23:37:34 05/02/14
There are many things I notice.
michaell32 (FL)
00:10:34 05/03/14
Re: There are many things I notice.
TwinTurboByrd
00:19:11 05/03/14
michaell32 (FL)
00:55:04 05/03/14
Re: A couple things I forgot to mention -
TwinTurboByrd
01:07:02 05/03/14
If your not making power at 15 degrees then something else
michaell32 (FL)
01:12:05 05/03/14
^^^This. You may have jumped a tooth on your belt.
ZaXxon
05:42:19 05/03/14
Re: ^^^This. You may have jumped a tooth on your belt.
TwinTurboByrd
13:12:23 05/03/14
Verify all cylinders are firing..spark and injectors
ZaXxon
15:16:55 05/03/14
Re: Verify all cylinders are firing..spark and injectors
TwinTurboByrd
18:13:11 05/03/14
I went through the same thing with the selin
Zvil (FL)
00:32:16 05/03/14
Re: I went through the same thing with the selin
TwinTurboByrd
00:43:40 05/03/14
they're fine turbos for the price
Zvil (FL)
21:32:09 05/04/14
