TwinTurbo.NET: Nissan 300ZX forum - You say Wideband.. Only One?
Subject You say Wideband.. Only One?
Posted by Cjw3 on May 02, 2014 at 11:53 AM
  This message has been viewed 503 times.
In Reply To The most frustrating and elusive idle problem ever posted by Silens on May 01, 2014 at 01:05 PM
Message Im of the opinion you need Two Widebands. Do you have Two.. if so, what is the reading of both at Idle..
Where is ( are ) the Widebands Located..
Does the ECU Prom Match the AIV's or No-AIV's Installed?
Do your Injectors match what is programmed in the ECU Exactly.. So the Fuel Trims are not having to adjust very Far??
That is all I got on this..
Cj
