TwinTurbo.NET: Nissan 300ZX forum - You could always plug the PCV vents and test at 7 psi
Subject You could always plug the PCV vents and test at 7 psi
Posted by SammybTT(TN) on April 27, 2014 at 9:33 AM
  This message has been viewed 136 times.
In Reply To Boost Leak? posted by DC3843 on April 26, 2014 at 09:39 AM
Message To determine if you have a boost leak. I have basically the same set up as you so I use soap/water mixture to locate leaks because mine vents to atmosphere as well.
