TwinTurbo.NET: Nissan 300ZX forum - Help with an unknown part by battery. Pic inside
Subject Help with an unknown part by battery. Pic inside
Posted by mfergus2000 on April 26, 2014 at 9:25 PM
  This message has been viewed 285 times.
Message First, the unknown part picture link:
Unkown Part Link
I did not post the image directly to this message because I did not resize it and it is fairly large.
I am working on my 91TT Z that isn't starting. I posted a message in the technical forum a couple of weeks ago and unfortunately I still haven't gotten the Z to start.
Link to original post:
Original Post
[ http://twinturbo.net/nissan/300zx/forums/technical/view/1143264/Car-Wont-Start-91TT.html ]
Today I was checking that I am getting spark by pulling a couple of coil packs and rotating the CAS to see if I get a spark. I did not see any spark from either coil pack. I checked the ohm reading on both and I got the recommended 0.7 ohms and the longer I held the meter to the coil the high it went up until it hit 1.3 ohms. I also had the fuel fuse near the battery pulled as not to dump fuel into the cylinders.
I was hearing clicking noises which I thought at first were the injectors but it seemed localized in only one spot, not around all 6 cyclinders. The clicking noise came from it seems the unknown part near the battery.
I have have now done the following:
Checked ECU codes: 55 no error
Cleaned PTU connectors
Diode checked PTU:
PTU Values
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/817092/ptu-values.html ]
Replaced fuel filter
Replaced fuel regulator
Replaced starter relay
Checked grounding cables on back pf plenum
Checked F23 by ECCS voltage: Read 10.3 Volts
Cleaned CAS connector
Rotated CAS to check for spark: Test failed, no spark
Thank you TT.net for all your help so far.
