TwinTurbo.NET: Nissan 300ZX forum - Re: If you use the NA transmission then use the aluminum
Subject Re: If you use the NA transmission then use the aluminum
Posted by rykersdad1 on April 26, 2014 at 6:25 PM
  This message has been viewed 219 times.
In Reply To If you use the NA transmission then use the aluminum posted by na300zx (OH) on April 24, 2014 at 09:18 AM
Message been busy with work but thanks for the reply. I am using the tt trans because my na trans had issues. i know i will have to grind the bellhousing to get the starter to fit but it something im willing to do for the rotating weight savings. seeing as how i have it and grinding the face of the bellhousing wont cost me anything i may as well use it. when i get the clutch buying i will be looking up joe at zspeed. thanks alot guys.
